3 flights new, foam still solid, no creases. Had a slight accident with the nose (not in flight) but as you can (not?) see, it's been perfectly patched up.
Fan unit has been re-balanced - no vibration.
Stock fiberglass stiffeners have been replaced with carbon rods.
Stock motor runs OK on 3 cells, 4 cells will be a LOT more fun...
Glides absolutely forever when power is cut, very good way to get into EDF.
New kit costs ~$300 at NTC, without servos and not assembled... I'm letting mine go for $250 with 3 servos, stock motor and fan.
Servos are 2x JR ES375 for the ailerons, and 1x JR NES-371 for the tail.
For another $50, you get a Hacker Master 40-3p ESC, plus wire harness for 2 packs in parallel.
SMS 96394711 if interested.
Thanks for looking!
Thanks for looking!
