FS Glitch reducer
    FS Glitch reducer
    FS Glitch reducer
    as per the add one of these up for grabs
    Price $17.50 ( $10usd plus pastage)
    here is how they work
    Glitch Reducer
    The Glitch Reducer will eliminate most glitches before they get to the servos or electronic speed controllers. It will constantly output the last known 'good' signal from the receiver. It will suppress any input signal outside of the signal range. It will also suppress the random input signals that are within the signal range.
    Our Dynamic Adjustment System (DAS) will never fully reject any input signal. Most signal filtering systems that reject signals can sometimes reject too much at crucial moments. Combined with an input averaging system, DAS will filter out glitches and will always put your servo or ESC where it needs to be.
    The Glitch Reducer is also designed to always output a good signal at the exact same rate as your transmitter. It automatically measures and averages the first couple signals to determine the frequency at which they occur. It will then output the correct signal at the same rate as your transmitter.
    Note: Glitch reducers have only been tested with seperate components. There may be an issue with having one or more glitch reducers on mixer boards. Mixer boards are the Piccoboard, Piccoboard Plus, Feda/Hummingbird mixer board, TREC with version 2.0 firmware, and anything else that mixes the main and tail signals together. If you are using revo mix in your transmitter, or a Heading Hold gyro, there should be no problem. If you have any questions, Please ask.
    sms if you are interested
    Cheers doug
    97526026
