Features :
New RealPhysics 3D for more realistic flying than ever before especially in high alpha (3D) flight, harriers, waterfalls and many more aerobatic manuevers are possible
Over 5000 square miles of flying fun with details such as trees swaying in the wind, clouds following the path of prevailing winds, glare changing in relation to the sun and background objects reflecting off the aircraft
Forty one total models from park flyers to 3D aerobats, slope soarers to Reno racers plus gliders-more choices than ever before
Easier and more powerful Aircraft Editor provides over 1500 different airfoils. Any desired aircraft modifications are graphically represented on the wire-frame model and reflected instantly on screen. Also sound will change when swapping a 2 to 3 blade propeller or changing prop pitch or diameter.
Ten unique airfields created from hundreds of megabytes of satellite imagery and digital elevation data.
Five wind fields for subtle variations. As winds collide their strength varies accordingly and aircraft will feel the "bump" of a thermal as they approach the top of a mountain or hill.
Interlink Plus Controller can also be used as an interface with most 4-10 channel FM or PPM-selectable radios that have a trainer jack. Interlink controller also features Multi-Mode allowing two pilots to fly on the same PC. Split-screen imaging allows free flight "tag" or one on one tutoring.
Expanded and enhanced Virtual Flight Instructor (VFI) includes additional maneuvers for pilots of all skill levels. Experienced modelers will be able to learn high-alpha 3D aerobatics from world class pilots.
360° walk around preview option revolves aircraft continuously also allowing top to bottom viewing, changing trim schemes can be viewed immediately in the preview box.
"Break Apart" Aircraft-in the event of a wing shear or collision the aircraft will continue its flight reflecting the damage as the pieces flutter to the ground.
Easy one-click installation-insert discs, click "Start" and enter serial numbers
Streamlined menus reorganized to bring the most often used functions to the front to cut search time.
