FS Glitch reducer
    FS Glitch reducer
    as per the add one of these up for grabs
    Price $17.50 ( $10usd plus pastage)
    here is how they work
    Glitch Reducer
    The Glitch Reducer will eliminate most glitches before they get to the servos or electronic speed controllers. It will constantly output the last known 'good' signal from the receiver. It will suppress any input signal outside of the signal range. It will also suppress the random input signals that are within the signal range.
    Our Dynamic Adjustment System (DAS) will never fully reject any input signal. Most signal filtering systems that reject signals can sometimes reject too much at crucial moments. Combined with an input averaging system, DAS will filter out glitches and will always put your servo or ESC where it needs to be.
    The Glitch Reducer is also designed to always output a good signal at the exact same rate as your transmitter. It automatically measures and averages the first couple signals to determine the frequency at which they occur. It will then output the correct signal at the same rate as your transmitter.
    Note: Glitch reducers have only been tested with seperate components. There may be an issue with having one or more glitch reducers on mixer boards. Mixer boards are the Piccoboard, Piccoboard Plus, Feda/Hummingbird mixer board, TREC with version 2.0 firmware, and anything else that mixes the main and tail signals together. If you are using revo mix in your transmitter, or a Heading Hold gyro, there should be no problem. If you have any questions, Please ask.
    sms if you are interested
    Cheers doug
    97526026
    I will take it..
      air trecker got in first dave but i got one spare for me so you can have that one.
      all out guys sorry sold out
        ok... thanks...
        You tried it? Does it work well??
          just went down then and was flying it with the p10 in giov mode and the axi ..no cutouts ..this arragement got me 4 cut outs in 5 min last time. so for me it works
          but i did notice a bit of lag or sluggishness in the gov mode I think that might be linked to the reducer but I dont use this mode anyway
          cheers doug
          will post of asap to both of you guys ..that might be next monday but will let you all know when I have sent them.
            or if you guys are close you can always pick them up from the school ( aussie school) if you are going that way save the trouble of pastage and tf'
            cheers doug
              Will try to pick it up from you tomorrow. Will call/SMS before coming down.
              Cheers!
              Up... Up... and AWAY !
                Just got the glitch reducer in the mail from Doug, tried it and realized it does not work with Berg receiver. Seems that Berg receivers already have glitch reducer incorported. So re-selling it away. It is new, so SGD17.50 to next guy, with postage. Or SGD15 if self-collect at my place...
