EAGLE CDC Ver. 6B Charger
    CDC Charger Ver. 6B. DC charger. Good competition charger for onroads/offroads.
    Going at $220.
    Condition very good, comes with box and manual.
    PM me.
    Normal Peak
    Use this mode for all standard charging applications. You can setup the unit to perform one peak or two peaks. You can setup the auto repeak delay time within the USER SETUP MODE. To turn off the 2nd peak, set the repeak delay time to zero.
    Fuzzy Logic
    This charge mode is especially useful for packs with a partial charge. The unit would first discharge your pack according to your preset discharge rate and then fully charge your pack.
    Partial..
    Use this mode only for Ni-MH cell(s). Certain Ni-MH batteries require a partial charge for long term storage. You can program the amount of partial charge in the USER SETUP MODE. 10 to 30% usually good for Ni-MH battery.
    Boosting..
    This mode is developed for racing application. You can get the most capacity and power from your batteries using this boosting function. The unit first partial discharge your pack momentarily follow by a preprogrammed fast charge, this increase battery temperature as well as it's overall voltage output. We suggest that you only use this boosting feature when your pack is cool. Never use the Boosting function when your pack is still warm.
    ADD Specification
    LCD............................................... ..... 2x16characters INDIGO Blue backlit LCD display
    BUTTONS......................................... Surface Panel Type Battery
    IR ......................................... mOhm
    Auto Repeak..................................... On/Off 1-60 Minutes(1minute step)
    Partial Charge ................................. 10-50%(10% step)
    Alarm Sound..................................... 6 Ring Tones (user selectable)
    Case Size............................................ 6.14"x 4.80"x 1.77" (15.6x12.2 4.5cm)
    Weight............................................ .... 24.54ounces(695g)
    Input Voltage(Power Source)......... 11.5-15 Volts DC
    Charge Battery Capacity................. 50-6000mA (50mA step)
    Charge rate(Super linear)............... 0.1-7.0A(0.1A step)
    Auto Trickle ...................................... ON/OFF
    Auto Trickle Value Discharge Rate................................. 0.1-20.0A(0.1V step)
    Volt Threshold................................... 3-20mV/cell for Ni-CD,3-15mV/cell for Ni-MH,
    Cycle Number.................................... 1-9 times(1 time step)
    Delay Time For After Charge......... 1-10 Minutes(1 Minutes step)
    Delay Time For After Discharge.... 1-60 Minutes(1 Minutes step)
    Cheers!!
    [SIGPIC][/SIGPIC]
    Forgot to add, meant for competition onroad/offroads.
    [SIGPIC][/SIGPIC]
      You not going to use it for this year's TAC??
        Oh no dude.. enough racing liao. hhehehee.. represent already, happy like fish. Muahahhahaa! I achieve something in life, wanna achieve for dreams now. My childhood dream to fly. Btw, when's ur next order for cox minis? wanna chip in. lemme know.
        [SIGPIC][/SIGPIC]
          No more MO. Back to your selling thread.
            Going at $200. (neg)
            PM me.
            Normal Peak
            Fuzzy Logic
            Partial..
            Boosting..
            ADD Specification
            Cheers!!
            [SIGPIC][/SIGPIC]
