Brand New in box Futaba 3VCS HRS FM40 3 Channel Tx with R203HF Rx
    Brand New in box Futaba 3VCS HRS FM40 3 Channel Transmitter with R203HF HRS receiver.(ordered 2 sets and this is the spare set,brand new untouched in box).This is the latest HRS version not the older PCM version.
    System Features
    LCD Contrast adjustment
    LCD backlight on/off function
    Servo monitor display
    HRS ESC Setup
    Throttle mode
    Assignable switches/functions
    Throttle servo neutral adjustment
    5 Point throttle curve (forward)
    Full three function set
    10 Model Memory (Standard)
    CAMPac Facility
    110 x 64 LCD w/backlighting
    High Response System (H.R.S.)
    Two function selection modes
    Brake mix
    ABS (Anti-lock Braking System)
    Throttle Acceleration function
    Throttle Speed function
    Start function
    Steering Speed function
    Switchable 7 colour LED pilot light
    Digital Electronic Trim with sub trim
    Function select dial function
    Function select switch function
    Display switch
    Adjustable throttle stick travel
    Adjustable stick angle
    Adjustable stick tension
    Direct software access (key functions)
    Plug in RF module (easy Xtal access)
    PPM/PCM/HRS switchable
    Sound port (for optional alarm earpiece)
    Exponential
    DSC with optional cord
    Servo reverse on all channels
    Dual rates
    2nd Dual rate - Steering
    Idle up
    Throttle ATL (Adj Travel Limiter)
    End Point Adjustment
    Engine cut function
    Timer (Up, Down, Lap functions)
    Lap Navigate timer
    Lap List
    Programmable mixing - two circuits
    Tilt mixing - marine function
    Fail safe function (HRS/PCM only)
    Model Name
    Rotary knob 3rd channel
    Level select
    Buzzer sound tone adjustment
    Going for $550.Interested parties,please pm me.Thanks
