We NOW have a new Outrunner Motor that have specs very similar to Hacker's A20-20L.....
Specifications:
Cell: 2S ~ 3S Li-Poly
RPM / Volt (Kv): 1022
No Load Current: 1A
Operating Current Range: 6~15A
Peak Current (15sec): 19A
Internal Resistance: 0.089ohm
Dimension (Diameter x Lenght): 28 x 31mm
Shaft Diameter: 3mm
Weight with Cables: 56g
Props: ~1047
Thrust : Developed for 340 ~ 600g.
Suitable For : Parkflyer models power by 3 cells Li-Poly batteries.
The 12 pole Outrunner type design creates MASSIVE TORQUE , therefore larger direct drive props can be used without the need for a gearbox.
Other Features : Oversize bearings design, curved Neo-magnets, and high efficiency stator design. This motor produces the most power at lower current consumption than other popular Outrunner designs!
The Motor comes with 3.5mm Male Gold Connectors already soldered and 3pcs of 3.5mm Female Gold Connectors.
We will be selling it at $65 but from now to end Dec '05, the special introductory price would be $58.50.
Accessories
~ It can go along with our BA101 Back-Mount with Adaptor @ $12/set. (This set can also be use with AXI 2208 and 2212 Series of Outrunner Motor too.)
~ It can go along with our PA101 Dia. 3mm Prop Adapter @ $7/set.
~ Spare Shaft @ $5/pc.
Please contact me at HP 9751 3775 if you are interested.
Thanks/Kang
Specifications:
No Load Current: 1A
Shaft Diameter: 3mm
Props: ~1047
Accessories
Thanks/Kang
