HI! Guys, I 'm selling off a highly good condition Hirobo SST Eagle Freya 60/70 size. Helicopter size of a 90 just change the gear set to 90 size engine if it is in used. Completly ready to fly just plug in your own receiver and do the setting that 's it you 're done. Here are the following list.
1. HIROBO SST EAGLE FREYA 60/70.
2. O.S. MAX-61 SX''WC'' Series.
3. HATORI Muffler HAT710.
4. A pair of FUNKEY blades( Main 680mm ).
5. A pair of FUNKEY blades( Tail 95mm ).
6. EX Vertical Tail Fin( 0414-190 ).
7. WC EX Landing Gear Set( 0414-188 ) Low Profile.
8. EX Radius Block( 0414-730 ).
9. EX Slide Block( 0414-731 ).
10. 2 x SSZ-II Mixing Arm( 0414-228 ).
11. EX WC Engine Mount( 0414-716 ).
12. EX Carbon Tail Rudder Control Rod(L-730)(0414-191 ).
13. Thunder Tiger TT Header Tank Set 60cc( PV 0311 ).
Electionics
14. Volt Spy( On Board Battery Monitor ).
15. HIROBO FREYA Switch Plate( 0414-198 ).
16. 4.8V 2400mah Flat Sanyo Sub C Type Nicd Battery Pack.
17. FUTABA GY401 With S9253 Tail Servo.
18. FUTABA S9151 Servo On Pitch.
19. FUTABA S9252 Servo On Elevator.
20. FUTABA S9252 Servo On Aileron.
21. HITEC HS-525BB Servo On Throttle.
22. Rx Strong Box For Receiver.
23. Remote Glow Adapter (Glow Plug Extention).
24. Main Blade Holder.
25. Plus Other Accessories Come With FREYA.
Interested parties please PM me For More Information.
Thanks You.
Jameswilliam.
Electionics
Thanks You.
Jameswilliam.
