**Admin, please advise if posted in wrong thread
I can't seem to find the V2 FMS 800mm warbirds in LHS, ad so am ordering a few units of just two models for now. If you are interested, please support.
2- FMS 800mm BF109 F V2 with FMS048 3X Stabilization @ sgd$140nett
Take note this is a V2 version and the famous Messerschmitt BF109 has many scale features including a 3 blade propeller and scale hub. The aircraft features a brushless motor, 20Amp ESC and 4 ready installed servos. Assembly takes minutes following the simple photo step by step assembly guide. The EPO construction gives a light yet resilient airframe that will take much punishment and just bounce right back into the air!
800mm Warbirds New Features:
1. Upgraded scale pilot
2. Steel landing gear
3. Upgraded 1700 KV motor for increased performance
4. Newly designed fuselage and wing
5. Scaled 3-blade propeller and landing gear
6. Detachable fuel tank.
7. Easy to assemble
8. Durable EPO Foam
9. Battery: LI-PO 7.4V or 11.1V 1,000MAH - 1,300mAh 15C
11. CG Position:45mm (From Leading Edge)
12. Material: Double EPO
13. Wing Span: 750mm (29.5in)
Expected re-stock early Nov. Contact me at 90489199 if you are interested for more details
7. Easy to assemble
8. Durable EPO Foam
