Hi guy letting go this plane brand new in box . ( Never open the box before ) ..
leh long leh long . $50 SDG only .. Cheap n gd ... Interested pls call or sms or whatsapp me @ 98381644 KK Thank u ...
This is the X-5 flying wing from Skywalker Technology. The X-5 has been specifically designed for FPV and UAV, customised for F-Tek stabiliser systems.
An awkward looking but fantastic flying FPV / UAV platform, moulded out of EPO so it's nearly indestructible!
This model offers a large amount of under canopy space, excellent glider performance, fast low power cruise speeds in the region of 60-70 kph.
The airframe was designed from the outset to take FPV and other video devices, the equipment bays have been laid out to suit FPV / UAV applications, there is a camera mount in the nose and the canopy is a bolt down affair. Transporting the airframe is easy, it's compact enough to be put in any car's trunk!
Nice design points are the moulded in wing reflex, outward canted vertical stabilisers, ventral finger grip, nose camera bay, screwed down canopy, moulded battery and FPV trays, exposed to the airflow- external ESC bay and moulded in cable runs.
Don't be fooled by its size, the payload capability is beyond your imagination. There are reports of hefty payloads in excess of 2200 grams being carried without issue!
Specs:
Length: 550mm
Wingspan:1180mm - fin tip to fin tip
Motor: 2212-2215, 1600-1900KV
Prop: 7x4 - 8x6
Battery: 2200mah 4S - 4000mah 4s
Empty Weight: 323g
Required:
3 or more channel radio system - with Elevon mixing capability
2 x 10g servos
Folding propeller
Brushless outrunner
Brushless ESC
Lipo battery
FPV or UAV system
Specs:
Length: 550mm
Prop: 7x4 - 8x6
Empty Weight: 323g
Required:
2 x 10g servos
Folding propeller
Brushless outrunner
Brushless ESC
Lipo battery
FPV or UAV system
