Brand new servoless landing gear retract and FPV camera mount
    1. Selling one brand new servoless landing gear retract $11(Ordered wrongly. Didn't know it was in my cart until I received it. I don't even fly plane.)
    The easiest way to put retracts in your plane. No need to install a control box, messy wiring or a complicated air system. Just screw in the retracts, connect to your Rx and youre ready!
    Reliable servo mechanism with metal gearing and a high torque motor ensures trouble free flying!
    Why bother with air systems when you can now have a realistic and reliable electric unit at a fraction of the price?!
    Landing gear not included with the servoless retractable system.
    Features:
    Robust landing gear strut and mounting bracket
    Built-in 10 seconds over current and jamming protection
    Integrated electric motor with a micro PCB
    Double shock absorption design, completely protect the gears
    Auto 90 degree twist when retracted
    Spec.
    Working voltage: 4.8~6V
    Speed: .08s/60deg 4.8v - 0.6s/60deg 6v
    Angle limit: 90 degree when retracted
    Operating temp: -10~50C
    Dimensions: 73.5x44x28mm
    Weight: 54g
    Shaft size: 5mm
    Mounting area size: 44mm x 41mm
    Length: 74mm
    Not suitable for a plane heavier than 4.7kg
    2. Brand new FPV Fiberglass Pan-Tilt Camera Mount $6. (Does not fit my camera)
    Light weight and easy to install. Our HobbyKing FPV mount system is a great way to mount your camera.
    Kit includes bearings, screws, ball/socket, threaded rod and pre-cut fiberglass board.
    Spec.
    Dimensions: 36x28mm
    Camera Mount plate size: 28x26mm
    Weight: 8g
    Servo type required: 5~10g
    Contact 81126475
    Thank you.
