due to hangar clearance I am selling:
![Click image for larger version Name: 20130617_170142.jpg Views: 1 Size: 222.5 KB ID: 1009712](filedata/fetch?id=1009712&d=1581654185)
![Click image for larger version Name: 20130617_170048.jpg Views: 1 Size: 244.6 KB ID: 1009713](filedata/fetch?id=1009713&d=1581654185)
This is a FPV Flying Plank. It's a custom build, one of a kind. Foam core wing, collapsible into 2 pcs, covered with oracover. Condition is 8/10, pretty new, few flights, some scratches here and there.
It was run on 4s 5000mAh (2x) for a total of 10000mAh. Flight time was over 1hr. The cruise speed was optimized, this is no foamy, so it's about 60km/hr at about 7-8 amps drawn. The wind penetration is outstanding. The launch is easy (a little uptrim, I always launched myself), because it's a tractor prop, no flying wing "zephyr" "caipi" or other disasters to be expected. It goes vertical on full throttle.
Configuration:
Wingspan: 1400mm
Length: 500m
Weight: 2.6kg (all in)
Propulsion: Hyperion Motor 85USD
Propeller: Aeronaut Cam-Carbon folding prop (optimized via ecalc.ch),15x8 10USD
ESC: custom Turnigy Plush ESC (added large heatsink) 30USD
Servos: Elevons (2x), digital hobbyking 60USD
FPV Camera: TBS 69 pixim installed in wing (170USD)
Keychain #16 (30USD)
was run on 1.2G video with a rangelink LRS.
installed!!!
Not included:
VTx + OSD
(takes maybe 30mins to have it ready)
link to a video when it was flying in the Alps
EDIT: 80SGD
Configuration:
Wingspan: 1400mm
Length: 500m
installed!!!
Not included:
VTx + OSD
EDIT: 80SGD
