Have 2 of these 4108-380KV Turnigy Multistar 22 Pole Brushless Multi-Rotor Motor to sell.
Motors are built with high-end 45SH magnets, high quality NMB bearings and High Poles counts for less noise, smooth and responsive power and increased efficiency.
They have custom motor mounting and all are precision balanced for smooth running, these motors are engineered specifically for multi-rotor use and are not based on airplane motors. Motor fitted with shimmed and pre-loaded NMB bearings and has 570mm long high grad silicon wires. It has dual prop mounting, either a bolt on 6mm shaft prop hub or the 12mm spacing bolt threw prop attachment with a precision upper thrust washer for an unlimited range of props.
Specs:
KV(RPM/V): 380
Lipo cells: 4-6s
Max power: 360w
Max Amps: 17A
No Load Current: 0.5A/10v
Internal Resistance: .225ohm
Number of Poles: 22P24S (22poles 24 stators)
Dimensions(Dia.xL):47 x 26mm Motor
Shaft: 4mm prop shaft: 6mm bolt on hub or 12mm hole to hole for bolt threw style props
Weight: 111g bolt hole spacing: 19mm * 25mm
Specs:
KV(RPM/V): 380
Lipo cells: 4-6s
Max power: 360w
Max Amps: 17A
