Hi Guys,
Need to give up my trusty hexa to someone who will take better care of her as I really do not have time to fly anymore.
Sad to do it but better then leaving her on the shelve at home.
Here's are her spec
1) Frameset : Tarot 690.
Component built and separated via 3 different layers to avoid interference between power, control and transmitter modules .
Critical component protected by clear dome shell.
Electronics
2) Wookong M 50 Waypoint w GPS
3) 6x TBS Simon K flash 30A ESC
4) 6X AXI 2814/22 765 KV heavy Lifter short shaft
5) IOSD mkII
6) DJI ZenMuse H32D for GoPro
7) DJI AVL 58 Video TX/RX
8) Futaba 8J 2.4GHz S-FHSS Radio with R2008SB RX
9) All cables shielded and protected with braided wire sleeve
10) 2x 3W Super Bright White LEDs (concealed beneath motor mounts with separate batt supply)
11) 4x 3W Super Bright Red LEDs (concealed beneath motor mounts with separate batt supply)
12) Aluminium transmitter and batt case
13) 6x Falten wooden props
14) 6x APC Composite props
15) 4x 8200mah 3S lipo
She is in Mint condition and has not even seen a hard landing since birth. In perfect ready to fly condition just need to charge batt and fly.
A lot of hours have been spent putting her together.
Asking $2200 for this see to believe beauty.
Call 97260928 for a no obligation chat and pics will be sent on request.
Thank you for your time buddies!!!
Here's are her spec
Electronics
5) IOSD mkII
