$150
Whatsapp 81848208
Frsky XM PLUS Receiver(ONLY BNF) Version
Specifications:
Brand name: GEPRC
Item Name: Hummingbird Racing Drone
Frame: GEPRC GEP-HX2 (3mm bottom plate thickness version)
-Wheelbase: 110mm
-Thickness of bottom plate: 3mm
-Thickness of side plate: 1.5mm
Motor: GEPRC GEP-GR1106 6000kv
Propeller: GEMFAN 2040 3blade
GEPRC STABLE F4 Tower (GEP-F4-BS12A-VTX58200-M)
-Flight Controller: Betaflight F4 OMNIBUS
-ESCs: 12A BLHeli_S/Dshot150/300/600 16.6(G_H_30/L_H_0)
-VTX: GEP-VTX58200 48CH Mini FPV Transmitter
Camera: RunCam Micro Swift 1/3" 600TVL FPV camera 2.1mm lens CCD (PAL Format)
Receiver: Frsky XM Plus (ONLY BNF INCLUDE)
Weight: 85g (without battery)
Flight weight: 120g (include 4s 450mAh battery)
Feature:
-The GEPRC flying team carefully calibrations PID, the factory to the binding receiver can fly.
-Using the mature GEP-HX2 frame, and the base plate to 3mm thickness, all 3K carbon fiber main board, strong resistance to fall.
-Using the GR1106 6000kv motor and Gemfan 2040 3 blade propeller and 3s 450mAh battery, perfect match, efficient and violent.
-Using STABLE F4 Tower, easy install, stable
-Using Runcam micro swift camera, make sure clarity
-Tested the best speed 120km/h+
BNF:
1x Hummingbird FPV Racing Drone
2x Gemfan 2040-3 Propeller
2x Battery Strap
1x XT300-M
1x Battery skid resistance
1x Frsky XM PLUS Receiver(ONLY BNF)
Whatsapp 81848208
Specifications:
Brand name: GEPRC
-Wheelbase: 110mm
Feature:
BNF:
2x Battery Strap
1x XT300-M
