Got this beauty 2 weeks ago, build it, maiden it and realised is a way too small for me
It has 7 docile flights before it went on the shelf.
Everything for this built has been bought brand new and due to the number of flights done, it all still is.
Here is the package:
- OXY 2 FE kit (Factory Edition)
- 3 x Lynx DS895 HV servos (Alluminum CNC case)
- 1 x BlueArrow H0988USH-i tail servo (special for OXY2)
- CC Talon 25A
- Lynx EOX 1611-5500Kv (3S - 4S motor)
- MicroBrain2 FBL
- 3 x 3S 850mAh Zolta lipos
- 3 x 3S Dinogy 100mAh 65C (3 flights on them)
- Miscellaneous parts (fathering shaft, main shaft, tail blades, NIP (190mm) orange main blades, 210mm black main blades....
The heli is built professionally, and what you need is just your rx to fly.
Some usefull notes here:
- The micro brain use JST 1.5 plug which means you cannot plug micro size servos (i.e. KST215).
- The heli support sub micro servos or glider servos which are not the micro size one.
- The Lynx servos that comes with, have JST1.5 plug so is a direct plug to the micro brain (meaning you
dont need any adaptor)
- The Micro Brain2 is the latest version in the market and it has not BT integrated.
- I had one hard touch down during the maiden which broke 1 plastic skid and it has been replaced with a - new one. No other damage or whatsoever.
The heli has been tested and set for 3D flight. It has absolutely zero issue.
It is not a toy, it can handle up to 6000rpm and hard 3D flights. Is a nice little heli which you can put in your backpack and sneak a flight wherever you are (Not valid for Singapore
I am asking a fair price of 580$ including the 3 lipos.
92712238 for pictures.
PS: Please don't contact me to ask me what is my last price. You will be ignored.
As stated, the heli has zero issue or defects. Everything is like new.
- CC Talon 25A
- MicroBrain2 FBL
)I am asking a fair price of 580$ including the 3 lipos.
