NEW Products at SG TOOLING
Sherline 3in1 Mill Lathe Combo - Best of both world.
Sherline lathe and Mill function in one machine. Compact and powerful, 90Vdc motor produce far more torque than the 1/2 HP AC/DC motors. Cuts Steel, Stainless Steel, Aluminum, Plastic, Wood etc....
Distance between center : 200mm
Cross Travel : 110mm
Graduation : 0.01mm
Electronically controlled speed range : 70 to 2800 RPM ( upgradeable to 10,000 RPM )
Overal dimension : 45cm ( L ) x 30cm ( B ) x 40cm ( H )
Now selling S$ 1199.00
Click here for more details
Dremel 110 pieces super accessory kit
Dremel 110 pieces super accessory kit in stock now!!
Dremel 7000-N/5 6V Cordless Two-Speed Rotary Tool
Product Information
- Includes five accessories and a wrench
- Rotates at two speeds: 7,000 RPM or 14,000 RPM
- 6-volt cordless Dremel rotary tool
- 260g Light weight suitable for field and outdoor
- 5pc accesories with wrench
Unbeatable price :- S$58.70 before GST ( S$62.81 after GST )
Dremel Tungsten Carbide Router #9901 & #9902
Tungsten Carbide Cutters are ideal for shaping, smoothing or removing material from especially hard materials.
•Shapes, smooths or grinds especially hard materials including: hardened steel, stainless steel, cast iron, nonferrous metals, fired ceramics, plastics and hard woods.
•A high-speed cutter made of tungsten carbide, the hardest material next to diamonds.
* Bit Diameter Inch: 1/8″
* Bit Diameter mm: 3,2 mm
* Color Code: Teal
* Description: Tungsten Carbide Cutter
* Shank Diameter: 1/8″, 3,2 mm
* Model Number:9901
* Bit Diameter Inch: 3/32″
* Bit Diameter mm: 2,4 mm
* Color Code: Teal
* Model Number:9902
Dremel EZ Lock 1-1/2" Carbide Cutting Wheel
The Dremel EZ Lock makes accessory changes easy as PULL - TWIST - RELEASE. The one-piece mandrel design simplifies the process of changing cutting wheels and makes it easy to cut through wood and laminates. For use with the EZ402 EZ Lock Mandrel.
•Now cut 1/2" wood and laminate
•Cuts wood fast with little effort
•Easy to assemble
Now S$19.90 only
Price before GST
dremel attachment
Dremel attachment now in stock!
Dremel Right Angle Attachment
Whether you're drilling, grinding or cutting, all sorts of hard-to-reach areas become instantly accessible with the Dremel 575 Right Angle Attachment. The quick connect system makes it easy to attach to the Dremel rotary tool and the coupling system allows you to rotate the attachment on the tool to achieve a perfect grip.
•Ball bearings and spiral bevel gears provide smooth and cool operation
•Coupling system allows you to rotate the attachment on your tool
•Quick connect system easily attaches to your rotary tool in place of the housing cap, with no tools required
•Compact, durable design for long-lasting, versatile use
Dremel Multipurpose Cutting Kit
The Multipurpose Cutting Kit allows for sturdy, controlled cuts in a variety of materials including: drywall, laminate, fiberglass, plastic and vinyl siding.
•Depth adjustment quickly sets correct cutting depth up to 3/4"
•Easy screw-on mounting to rotary tool
•Large window provides excellent visibility for better control
Dremel Circle Cutter & Straight Edge Guide
This innovative attachment is the simple way to cut circular holes in many types of materials. It attaches easily to the Dremel High-Speed Rotary Tool and cuts perfect circles from 3/4" to 12" in diameter. The attachment has convenient measurement guides in both inches and centimeters, so you can cut out the right-sized circle every time.
•Makes circles from 3/4" -12" (1.9-30 cm)
•Precision stamped steel construction for accuracy and durability.
•Attaches quickly and easily without tools.
•Depth adjustment allows easy setting of the correct cutting depth
•Straight Edge Guide allows routing or cutting in a straight line
dremel attachment
Dremel Mini Saw Attachment
The Dremel Mini Saw attaches to the rotary tool in seconds and makes clean, straight, perpendicular cuts up to 1/4" thick. Works great in wood and all wood-like materials. Use for DIY, hobbies, crafts and modeling.
•Quick Connect System attaches to your rotary tool in seconds
•Make clean, straight perpendicular cuts up to 1/4" thick
•Angled throat allows for straight, perpendicular cuts
•Clear housing for better visibility
•Directional guide indicates direction of cut and line of cut
•Lower guard retracts when not in use to ensure safety
Proxxon Vise
Proxxon Precision vise FMS 75
Rotates in all directions. Made of die-cast zinc.
A strong suction cup facilitates instantaneous fixing to any smooth, flat surface.
Ball and socket: rotates in all directions (even downwards).
75mm jaws with protective covers (for delicateworkpieces).
Maximum clamping width 70mm and weight 1.6kg.
Price S$68.20
Price before GST
Proxxon Precision vise FMZ with integrated clamp
Easily clamps to workbenches and tables of up to 60mm. Alternatively, use 2 standard screws to secure to thework surface.
Price S$68.20
Price before GST
The most popular 110pcs dremel accessories and Dremel 7000N5 is back in stock.
Product Information
Update with new video
Dremel Precision Drill Bit Set
Wood Drill Bit Set (4 pcs)
The Dremel wood drill bit set contains 4 drill bits with centering point for drilling into wood. The different drilling diameters included are 3, 4, 5 and 6 mm. The titanium coating offers high performance and longer lifetime.
Technical specifications
Shank diameter: 3,2 mm
Usage: Unique Dremel Titanium wood drill bits with diameter 3, 4, 5 and 6 mm.
Maximum RPM: 35.000 1/min
Dremel Plunge Router Attachment
Converts your Dremel tool into a plunge router to rout circles, signs and inlay work, decorative edges and to rout parallel to an edge. Plunge-lock in handle - simply turn handle to lock/unlock. Two depth stops for quick, consistent adjustment of depth. Edge guide and circle guide to rout straight lines and perfect circles. Guide bushing set for letter and pattern template routing.
Features and Benefits
•Converts your Dremel tool into a plunge router to rout circles, signs and inlay work, decorative edges and to rout parallel to an edge.
•Plunge-lock in handle - simply turn handle to lock/unlock.
•Two depth stops for quick, consistent adjustment of depth.
•Edge guide and circle guide to rout straight lines and perfect circles.
•Guide bushing set for letter and pattern template routing.
Contents
•Plunge Router Attachment
•Edge Guide
•Circle Guide
•Guide Bushing Set
•Wrench
Dremel 300-30 While stock last!
This kit includes the Dremel 300-Series multitool and 30 accessories , all packed in a convenient bag.
Because of the included accessories you can immediately start working with your Dremel.
Features and Benefits- New and unique design - Improved ergonomics and increased comfort
- Comfort switches - More comfortable when handling and better control
- Variable speed 10.000–33.000 RPM - To match speed to the project at hand
- Second attachment interface - To attach DREMELite
- On-board wrench storage - To have the wrench always at hand
- Integrated hang hook - For hanging the tool while working with the Flexible Shaft
- Soft grip - For reduced vibration and a better grip
- 125W motor - Optimal performance
Contents - Dremel 300 Series
- 30 high quality Dremel accessories
- Soft bag
- Instruction manual
- Inspiring welcome poster
Usual PriceS$ 135.20
Unbeatable price :- S$99.00 before GST
Dremel Multi-Vise
The Dremel Multi-Vise helps you secure your project or free up a hand for extra control when using your Dremel rotary tool. The removable cushioned jaws help protect delicate workpieces while providing a firm, steady grip.
Features and Benefits- Rotates 360° and tilts 50° allowing the user to lock the workpiece in any position
- Clamps to any work surface up to 2-1/2" thick
- Tool holder turns Dremel rotary tools into a stationary sander, grinder or polisher
- Removable clamping jaws create a stand-alone bar clamp
Includes - Vise head, tool holder and adjustable base
Price S$ 69.90 before GST
Proxxon Diamond Cutting Disc
Diamond cutting discs Only 0.6mm thick.
For cutting and sanding of porcelain, ceramics, glass fibre boards, plastic and nonferrous metals.
Shaft of Ø 2.35mm.
Diamond-coated cutting discs with cooling holes For cutting, grinding and deburring.
Same applicationas described above. Less heating up due to cooling holes.
No burn marks!
Shaft ø 2.35.
Best for carbon fibre rod / board!
Back in stock
Back in stock! Limited units!
- Soft bag
