SG TOOLING: Proxxon - TOOLS WITH CHARACTER
    We are pleased to announce we carried the full range of Proxxon tools. Need no introduction for these tools which is best known for its QUALITY.
    Check us out @ http://shop.sgtooling.com
    SG TOOLING
    Website:
    Sherline Mill
    Sherline Lathe
    CNC Ready Package
    Very cute size. Love to have them but later kena big scolding.
      Arrival of New Proxxon Stuff:-
      and many more. Click here for further infomation
      SG TOOLING
      Website:
      Sherline Mill
      Sherline Lathe
      CNC Ready Package
        Mitutoyo precision measuring instrument is now available @ SG TOOLING
        SG TOOLING
        Website:
        Sherline Mill
        Sherline Lathe
        CNC Ready Package
          Back to your roots?
            Do you have any specs of the torque wrench?
              Back to your roots?
              Help sell some good stuff ...
              See the attached catalog
                Mike: Where can I see this torque wrench? Does it take the 2,3,4,5mm allen key.
                Whiplashing soon?
                Crash records counter
                JR Vibe 50: 01
                Trex600N Pro: 01
                Kasama Srimok 90: 01
                TT Raptor 50: 10
                TT Raptor 90 3D: 01
                MA Fury 55: 01
                  your web only have click 30?
                    Proxxon table vise
                    Arrival of some new Proxxon table Vise
                    Price and products details Click here
                      Proxxon hand tools
                      Check out this latest arrival of Proxxon hand tools!
                      All unit comes with Head of die-cast zinc, ensuring exact and stable housing for the moving parts. Allows precise and stable storage of moving parts
                        Proxxon Tools
                        Tools that can be trusted. Really value for money.
                          Proxxon Parallel Bar Set
                          Finally, a suitable size precision ground parallel bar set is available now from PROXXON.
                          PROXXON 14-piece parallel supports set
                          For adjusting work on drill machines, lathes and milling machines. Of high-alloy steel, hardened (58 - 62 HRC) and ground in pairs. Parallel accuracy 0.002mm.
                          2 each of 8 x 10, 15, 20, 25, 30, 35, 40 and 100mm. Packed in a wooden box
                          Details here
                            Pre-Order for Proxxon TBH Drill Press
                            We are working on a PRE-ORDER for one of the best Drill Press around in the market - PROXXON TBH Drill Press
                            Technical Specification:-
                            • 220 – 240 Volt.
                            • Spindle rotational speeds 1,080, 2,400 and 4,500rpm.
                            • Sliding sleeve stroke 63mm.
                            • Height adjustment via crank 70mm.
                            • Throat 140mm. Usable table surface 200 x 200mm.
                            • Column 45 x 500mm.
                            • Weight approx. 10kg
                            Pre-Order Price S$ 688.90 before GST
                            Due to the weight of the machine, pre-order open for 5 sets only and will not extend. Pre order close as soon as we receive order for the 5th unit.
                            Email: sales@sgtooling.com
                            Website: http://shop.sgtooling.com
                              New Arrival !!!!
                              Professional drill/grinder IB/E
                              Specification:-
                              • For drilling, milling, grinding, polishing, cleaning, cutting, carving, engraving and signing.
                              • Streamlined head of die-cast aluminium forexact bearing seats and optimal stability.
                              • Quiet, powerful 100W motor with full wave electronics for speeds between 5,000 and 20,000rpm.
                              • High concentric accuracy (maximumrunout 3/100mm).No runout in your bits and cutters.
