New Products in RCS
    Originally posted by johndyl View Post
    ken, paiseh.. your c5 pinions kinda look like the rhino gears with the long shank(flat part) .. do they come in 17 or 18t?
    Sorry, i do not have the pinions only
      CSM products are back in stock
      1) CSM Carbsmart
      2) CSM RevLock 20
      3) CSM Revlock 30
      4) CSM USB Link
      5) CSM SL720 Gyro
      6) + accessories
        Miniature Aircraft X-Cell Furion 450 Kit has arrived
          Various Packages for X-Cell Furion 450
          We understand the higher prices of spare parts for all top end helicopters, hence we are extending our support for all our Furion customers with up to 15% Discount of Furion spare parts.
          Quality is a previlege you deserve, join the Furion Club now
            I am arranging for an order from Outrage and HeliDirect, please contact me if you wish to make any special order enquiries for their products.
            Please send item code and quantity via PM or email: enquiry@radiocontrol-sports.com
            Closing date:
            28 May 09 1000 hrs
              Western Robotics BEC & Optical Tach Back in stock
              Western Robotics Hercules BEC High Current
              Western Robotics Hercules Super Mini BEC
              Western Robotics Hercules Super BEC
              Western Robotics Chinook Optical Tach Elite
                Promotion Offer: SGD$310.00 (Limited Qty, Walk-in Cash Sales Only)
                  JS Model Frenzy 50
                  Back in stock
                    pls ignore.
                      OMI ELD Fuel Magnet
                      OMI Fuel Magnet Replacement Foam (3pcs)
                        Switch Mode Power Supply (Schaltnetzteil 13,8V 30A)
                        Switch Mode Power Supply (Schaltnetzteil, regelbar 5-15V/0-20A)
                        Switch Mode Power Supply (Schaltnetzteil 12V/25A 300W)
                        Switch Mode Power Supply (Schaltnetzteil 13,8V/40A)
                          Spartan DS760 SMM AVCS Gyro
                          Spartan Flash-Link USB
                            G5 Flybarless Swash Driver Base ONLY
                            G5 Flybarless CNC Radius Arm & Swash Driver Lever
                            ~~~450 class Flybarless modifications with the above swashplate follower setup~~~
                              Graupner ULTRAMAT 14 plus
                              Description
                              Low-cost computer-controlled all-purpose fast charger
                              With integral lightweight switch-mode mains PSU for 100 ... 240 V and 12 DC input. This makes the charger an excellent choice for using on the road in any location, and even abroad (USA / Japan)
                              Graupner balancer socket for 1 ... 6 NiCd/NiMH/LiPo/LiIo/LiFe batteries
                              Automatic charge program for NiMH and NiCd batteries as used in modelling
                              Ultra-simple to operate, with clearly arranged program structure and four buttons
                              High-contrast, blue backlit LCD screen displays all relevant parameters simultaneously
                              Charge facilities for NiMH, NiCd, LiPo, LiIo, LiMn, LiFe and lead-acid batteries
                              Delta-Peak Cut-Off detector for NiMH and NiCd cells with user-variable Delta-Peak voltage, ensuring full charges to 100% capacity at all times
                              Capable of charging single cells, therefore ideal for glowplug energizer devices
                              Charges LiPo, LiIo and LiFe cells using constant current / constant voltage method. Declining current curve after reaching final charge voltage, with automatic power-off
                              Lead-acid charge programs with optimised charge curve
                              Protected against short-circuit, overload and reversed polarity
                              Switchable buzzer
                              Switchable safety timer
                              Selectable screen language: English / German / French
                              Display of internal battery resistance in manual NiMH and and NiCd mode
                              Display of individual cell voltages for 2 - 6 cells in NiCd / NiMH / Li mode
                              Ready to connect
                              Specification
                              Operating voltage range DC input: 11 ... 15 V/8.5A DC or 100 ... 240 V AC mains voltage
                              Charge facilities: 1 ... 14 NiMH / NiCd cells, 1 ... 6 LiPo/LiIo/LiMn/LiFe cells, 1 ... 6 lead-acid cells
                              Charge current: 0.1 A ... 5 A in mains PSU mode (max. 50 W), 0.1 A ... 5 A in 11 ... 15 V DC mode (50 W)
                              Balancer socket: 1 ... 6 NiMH/NiCd/LiPo/LiIo/LiFe cells
                              Max. balancing current approx. NiMH/NiCd: 0.1 A, LiPo/LiIo/LiFe: 0.3 A
                              Dimensions approx. 148 x 146 x 54 mm
                              Weight excl. mains lead approx. 600 gAll data assumes a car battery voltage of 12.7 V.
                              The stated values are guidelines, and may vary according to battery state, temperature etc.
                              1 )When powered by a mains PSU, the charger will only operate correctly if the PSU is suitable in terms of voltage, stability, maximum load capacity etc. You can avoid problems by using only the PSUs which we specifically recommend.
                              Instruction Manual Link
                                Graupner ULTRA DUO PLUS 40
                                Description
                                Computer-controlled universal fast-charger
                                Stacks together easily with the external mains PSU, Order No. 6460, forming a compact unit.
                                Two independent charge outputs
                                Graupner balancer socket for balancing and displaying individual cell voltages for 1 ... 14 NiCd/NiMH/LiPo/LiIo/LiFe cells at Output 1, and for 1 ... 4cells at Output 2.
                                Display of internal resistance of individual cells, for checking cell quality with pack connected to balancer socket at Output 1.
                                Forty battery memories for storing all important battery parameters, with copy function.
                                Battery memories and data can be programmed and backed-up using a PC.
                                Discharge voltage curves can be read out subsequently using a PC.
                                Mains PSU function, max. 120 W: user-variable voltage 0 ... 24 V, and variable current limiting.
                                Automatic charge, discharge, capacity measuring, battery maintenance and conditioning program for NiMH, NiCd, LiPo, LiIo, LiFe batteries as used in modelling
                                Ultra-simple operation with clearly arranged programstructure controlled by three buttons and rotary knob button
                                High-contrast graphic LCD screen (128 x 64 dots / 21 x 8 characters) with blue backlighting, for displaying all relevant parameters or charge / discharge curves
                                Charge / discharge facility for NiMH, NiCd, LiPo, LiIo, LiMn, LiFe and lead-acid batteries
                                Delta-Peak Cut-Off detector for NiMH and NiCd cells withvariable Delta-Peak voltage, ensuring reliable charging to 100% capacity
                                Capable of charging single cells, therefore ideal for glowplug energizers and cell selection processes
                                Charges LiPo, LiIo, LiFe, lead-acid cells with constant current / constant voltage method. Declining current curve after the final charge voltage is reached, with automatic charge termination.
                                Charge processes:
                                NiCd / NiMH: automatic, normal, linear, GMVIS, IMPULSE, REFLEX, REPEAK, stepped charge
                                LiPo/LiIo/LiFe: automatic, CC/CV, CV-link
                                Special charge facility for storing batteries
                                Balancer program
                                Data memory for comparing all important battery data
                                Lead-acid battery charge programs with optimised chargecurve, discharge facility, variable discharge current for determining battery capacity and residual capacity
                                Program for tyre heating covers, Order No. 94711, with temperature regulation, or for battery heater, Order No. 8375, in LiPo safety case, Order No. 8370 or Order No. 8371.
                                Motor run-in and test functions for brushed electric motors
                                Short-circuit, overload and reverse polarity protection
                                Switchable buzzer, selectable melody
                                Variable safety timer
                                Variable maximum charge capacity
                                Selectable screen language: English/German/French/Italian
                                PC-USB interface for displaying battery curves
                                Ready to connect
                                Specification
                                Operating voltage 11 ... 15V / 25A DC, max. 250 W total
                                Charge facilities
                                Output 1: 1 ... 30 NiMH / NiCd cells, 1 ... 14 LiPo/LiIo/LiMn/LiFe cells, 1 ... 6, 12 lead-acid cells
                                Output 2: 1 ... 10 NiMH / NiCd cells, 1 ... 4 LiPo/LiIo/LiMN/LiFe cells
                                Charge current
                                Output 1: 2 x 0.1 A ... 10 A (max. 250 W)
                                Output 2: 2 x 0.1 A ... 5 A (max. 50 W)
                                Discharge current, Output 1: approx. 0.1 ... 10 A (2 x max. 80 W)
                                Balancer socket
                                Output 1: 2 x 1 ... 7 = 1 ... 14 NiMH/NiCd/LiPo/LiIo/LiFe cells
                                Output 2: 1 ... 4 = 1 ... 4 NiMH/NiCd/LiPo/LiIo/LiFe cells
                                Max. balancer current approx. NiMH/NiCd: 0.1A, LiPo/LiIo/LiFe: 0.3 A
                                Dimensions approx. 180 x 155 x 62 mm
                                Weight approx. 990 g
