RC-Warbirds is happy to bring you the latest range of Velocity-RC Products.
Designed by European EDF Professionals the Velocity-RC EDF Jets feature a perfect EDF duct work for best performance, light weight structure and beautiful finished smooth surfaces.
Latest Arrivals:
Velocity-RC SlingJet EDF Trainer
The Velocity-RC SlingJet EDF Trainer is the perfect first high performance EDF Jet for the first time EDF Pilot (experience on aileron controlled RC planes required).
The SlingJets big speed envelope allows the plane to fly fast but handles equally well at slow speeds. Designed for a 70mm EDF Fan such as the Velocity-RC WM400, WeMoTec Mini Fan 480 or the HET-RC 6904 and powerful brushless motors such as the HET-RC Typhoon 2W, 3W or 2W-20 EDF.
The universal 70mm power setup allows the pilot to re-use the same components for all other 70mm Fan EDF Jets in our portfolio once graduated from the SlingJet.
The SlingJet ARF Kit features a professional covered lite ply/balsa fuselage and control surfaces, ready covered foam core balsa wings and a fix landing gear for take of from ground.
The Velocity-RC Dassault Mirage 2000 is a high performance Jet designed for the Velocity-RC WM400 70mm EDF unit or similar sized fans such as the WeMoTec Mini Fan 480 or the HET-RC 6904 and powerful brushless motors such as the HET-RC Typhoon 2W, 3W or 2W-20 EDF. The ARF kit features a beautifully finished gray fiberglass fuselage with balsa sheeted and oracover covered foam wings. The high pre-fabrication grade of the model allows for the first sorties in no time.
The plane was successfully flown with retracts before - slight building required.
Arriving Soon:
Velocity-RC Lockheed T-33 Shooting Star
RETRACT READY !!!
The Velocity-RC Lockheed T-33 Shooting Star is a high performance Jet designed for the Velocity-RC WM400 70mm EDF unit or similar sized fans such as the WeMoTec Mini Fan 480 or the HET-RC 6904 and powerful brushless motors such as the HET-RC Typhoon 2W, 3W or 2W-20 EDF.
The ARF kit features a beautifully finished, retract ready gray fiberglass fuselage with balsa sheeted and oracover covered foam wings. ROG with the included fixed or the optional available retractable landing gear is possible.
The high pre-fabrication grade of the model allows for the first sorties in no time. Thanks to the pre-installed retract mounts the installation of retractable undercarriage can be done in a very short time.
More Infos will follow soon !!
