Dear All,
This week's offer from Radio Modellers is the Active Throttle Governor from Curtis Youngblood.
Price is @ S$135.00
We are proud to introduce a new throttle governor developed and flown by Multi-time World Champion Curtis Youngblood. This Dual Mode Governor features simply push button setup, rpm indication lights, and a small slim case. Compatible with G-view display
Modes of Operation
Basic mode- a simple, quick start option for setting up the ATG. Set the rpm range via push button and indication lights and go fly. Nothing but basic curves needed.
Active Throttle Mode- Much more than just a limiter. In Active Mode ATG allows you to run your throttle curves and mixes to optimize engine performance, while still governing to to a set RPM. ATG passes through all your throttle curves and mixes and simply modifies that signal as needed to keep your set RPM.
Note! When going through initial setup please do Quick setup (steps 1- 12) first. See product info below for instruction corrections. See Tech specs for setting ATG V1 with G-view.
Note!! ATG is rated up to 12V
Grab yours today @ www.radiomodellers.com
Offer ends 3rd Feb 2008
Radio Modellers
Authorised Dealers For The Following :
- Curtis Youngblood
- Aztech RC Youth Electronics
- Scorpion Motors And ESCs
Price is @ S$135.00
Modes of Operation
Radio Modellers
- Curtis Youngblood
