We have successfully converted the 25 size Nitro WUYUAN into EP power using REVOX A36-16M powered by REVOLUTION 3000mAh 11.1V 20C Lithium Polymer. Using 70A Opto ESC with a 3A External UBEC, we are able to give a remarkable headroom for amp draw with an APC 12 x 6E.
Changing the engine mount into motor was a breeze. You will need to DIY yourseld by using the aluminum body frame spacers from RAPTOR90 and fixed them onto the firewall like standoffs. You have to use 2 cross radial mount for this. We will try to get the pictures soon...
Flying : Superb Stability for torque rolling and landing was really a breeze with the CG just enough for aft manoeuvres...AUW is only 1.4KG with battery inserted on the belly for easy access.
You can watch the video here (special thanks to Edmund22 for the footages):
VIDEO
The WUYUAN 25 is available through us.
For those who are interested, you can take a look at the modifications at our shop and we will be glad to share the modding tips.
Regards
