Rescue boat pushed submerged helicopter to shore at TQ on 30th Oct 2010
    A rescue boat specially built to retrieve detached floats of Multiplex TwinStar II pushed a submerged helicopter to the shore for its owner to retrieve it. The helicopter was on a test flight. It overturned after a landing when its tail rotor hit the water. Only the floats of the helicopter could be seen above the water surface. The helicopter was submerged in several feet of water.
    That is why for seaborne (correction, should be sea based) helicopter, it is better to be in elevated tail configuration.
    SH
      Nice and cool operation
        an expensive operation...
        heli servo, gyro, receiver, bearings /linkages and on board camera
          Recently my scale heli was dipped on water..not deep but enough to flooded some avionics. For my case, it is the external BEC got flooded with water and causes the o/p voltage to goes to very high (to like 6S1P from the i/p voltage) and that causes the following damage:
          1. one Hitec HS-5065 burned with smoke.
          2. logictech 2100 gyro burn.
          3. Navigation lights controller.
          THe logictech 2100 still can recover by bypass the what appeared to be a voltage regulator inside it. The gyro is still working but I think there is some damage whereby at idle state, it will slowly move to one side.
          For 3, it is ok because I can reprogram a new PIC microcontroller.
          SH
            The water is merciless. Haiz I share your pain man...
              The GoPro is ok? It should be. Its in a waterproof case.
                Just for your information...the heli was flown again after 5mins...No damage..
                All electronics are coated with waterproofed agent....
                  Got to get some of the stuff.
                  Having fun yet?
                  36.39mhz
                  40.77mhz
                    SH
                    I sorry to hear about ur loss. It pain and expensive hobby nevertheless it plenty of fun once things get going!
                    Warpath Wong
                      Cool! can show how you did the water proofing?
                        Really? I'm surprised! Good for you.
                          Bro, Mave, you got pm.
                            Got it! Thanks Bro!
