Home built DIY Electric Balsa Bi Plane
I will try PFW this Fri morning but I think the dihedral is too little to roll the aircraft. Let's see how. Another pilot built this with dihedral a little too much hence I half the angle.Scratch building is more than cutting balsa wood and gluing them. Its a complex process that will test even the most resilient of people
What's this plane, by the way? I don't remember seeing the plan before..."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
Originally posted by csisfun View PostNice!!! Seems like you made a few modifications such as a boxy fuse and a solid tail surface.Scratch building is more than cutting balsa wood and gluing them. Its a complex process that will test even the most resilient of people
Originally posted by Sunstorm View PostWhat's this plane, by the way? I don't remember seeing the plan before...Scratch building is more than cutting balsa wood and gluing them. Its a complex process that will test even the most resilient of people
It's possible if you have enough dihedral. I've done that several times with my Buttercup.
I read an article in model airplane news magazine many years ago. It mentions that for a model to have yaw induced roll ( we are not talking about 360 degrees roll here), it needs to have at least 3 degrees of 'effective dihedral'.
Effective dihedral takes considerations of wing position, wing sweep and actual dihedral, instead of just actual dihedral angle alone.
An average high wing model already has 1 degrees of positive dihedral even with a flat wing. An average low wing mdoel has 1 degrees of negative dihedral. So, for the high wing plane to turn with rudder, you'll need 3-1=2 degrees, and low wing is 3+1=4 degrees minimum.
For models with very deep fuselage or wings mounted very high up like parasol wing configurations; ie very low CG, they have so much positive effective dihedral that even with flat wings, the rudder is enough to roll the model.
Sweep angle also makes a difference. For every degree of sweep back, you'll get a half a degree of effective dihedral. Forward sweep will have effective anhedral on the other hand. I ever designed and build a model with flat wing but have swept back wings with about 10 degrees. It didn't have ailerons and I could fly it normally with elevator and rudder alone.
For you case, the lower wings may have insufficient dihedral, but the upper wings may have just enough. Since the wings are done, try other means by shifting the CG as low as possible. Place all your servos and battery pack at the bottom of the fuselage and use heavy wheels. In the worst case scenario, change the wingtips to something with some polyhedral.
