hi... tubine guys out there... where and when u ppl exactly play ur plane??? newbie here reali wish to take a look at them... COOL PLANE... and by the way erm... sg govt nv say thing abt this kind of plane?? cos i personally thing its rather dangerous..
i heard it cos 25k to get a basic set... is it true?
25k? Way off.
A standard turbine setup with simple airframe would put you back anywhere from 3-7k.
Thrust of turbine and size of airframe all play a part as per usual.
This includes the turbine engine itself, ECU and all the necessary hardware.
I don't have one, i just like doing my homework.
Thanx!
SLOPE SOARING NOT A CRIME
Basic start will not cost that much, as what wei Yao mention the basic is about 3 to 7K only. I think the 25K is those big scale one where you need more thrusting power engine that will cost around 4 to 6K just engine alone. Let's say the scale jet needs 12 servo on control & one servo with hight torque cost around $200 X 12 will give you about $2400 plus engine let's say 5K for a 36lbs or 16kg thrust is already $7400, fuselage $3K that will bring you up to $10.400 there's other things which is not mention close to what it is..............
Discover the CAT percentile required for admission to the top 5 IIMs—Ahmedabad, Bangalore, Calcutta, Lucknow, and Indore. VerbalHub provides expert guidance, cutoff insights, and preparation strategies to help you achieve your target percentile.
