What is Dual rate?
    What is Dual rate?
    Originally posted by nic
    Check for Dual rates if you got it set... If you can't handle high rates, better fix it down... otherwise you might lauch the plane/heli at the wrong settings...
    Don't leave your TX hanging by the neck strap around your neck when you set your micros down on the floor... you might accidentally shift the trottle stick as the Tx goes swinging around by the neck strap....
    hi,
    can u explain further abt the dual rates stuff... i dun really understand.. im new to dual rates thnkx
    Sorry I moved your thread here so that the "safe flying" topic will remain only on flying safety..
    try reading for the answer to your question:
    The Academy of Model Aeronautics is a nonprofit community of enthusiasts who come together to celebrate model aviation.
    The best way to understand is, read your TX manual on how to set it.. then as an exercise, set it to your rudder to 75% dual rate.. and see what happens as you move your stick when you turn it on/off.
    Same goes Exponential. Do remember to reset it back if you not using it.
    huh
      ok got the idea of it. thnkx
