does anyone know the optic6 which our LHS r sellin are the newer batch or older ones...coz me wana get one but scared the older batch got lotsa bugs leh...anyone bought o6 recently, care to enlighten? Thx Thx
Optic6 firmware
Originally posted by almtmdVer 11 fixed all the bugs.
Not sure if they have new one.
You can check:
Press both Edit buttons and switch on power.
Press one of the Edit button until you see "VER 11"
mine was from rotor about 2 or 3 months ago
so far so good. anyway what kind of bugs do the older versions have?
Glitches considered as bugs?
I checked mine too. its also labelled "V1.2" on the chip
could be the one u are referring to
if thats really the case then "Ver 11" means "version 1.1"?
then the one rotor selling would be an even newer version !
btw this is the chip i checked...
its mounted on a chip carrier so i believe its Optic 6's main processor
cos microprocessors are usually mounted on chip carrier to make it easier to
remove it to reprogramme, update firmware or simply change a new one...
