Which budget 9g servos? TowerPro SG9xR? EMAX ES08A? HXT900?
    Hi all,
    What are your favorite 9 gram servos?
    EMAX ES08A seems interesting, JetHobby lists it at same price as the TP SG91R.
    3 for $20.
    Any one tried it before?
    Model: ES08A
    Working voltage: 4.8-6.0v
    Torque: 1.5kg.cm @4.8V / 1.8Kg.cm @6V
    Speed: 0.12/0.10sec/60°
    Size: 32 x 11.5 x 24mm
    Weight: 8.5g / 0.29oz
    Dead band width: 1-2 usec
    Wire length: 23cm
    connector type: Futaba/JR compatible
    Model: SG91R
    weight:9g
    Dimension: 23*12.2*29mm
    Stall torque: 1.8kg/cm(4.8V)
    Operating speed: 0.1sec/60degree(4.8v)
    Operating voltage: 4.8V
    Temperature range 0℃_ 55℃
    Dead band width 10us
    HXT900
    Size : 21x12x22 mm / 0.74x0.42x0.78 in
    Voltage : 3v ~ 6v
    Weight: 11g / 0.39oz
    Speed : 0.12 sec/60(4.8V)
    Torque : 2.5 kg-cm
    Working Temp : -30C~60C
    Plastic Bushing, 25cm wire, coreless motor
    Servo arms & screw included
    Gears: Nylon White type
    hxt900 and tower pro seem to be identical.
    both work well in parkfliers and lower rated funjets and stuff.
