gyros
    gyros
    what gyro do i need for my cp hornet?
    any cheap upgrades in a singapore hs for ms parts?
    my bl hacker motor is vibrating is it broken?
    Hello proman_11
    Well.. It doesn't matter what gyro to use. Better gyro will give u better performance and u do not need to apply i/p too often.
    Try get a Heading Hold Gyro. U can use Futaba GY240 or GY401 (if u have extra channel).
    As for MS parts, I think there is only one LHS that u can get right now.
    As for Hacker motor vibrating... where is it vibrating are u refering. Are u refering to the motor itself or when u mount onto your helicopter?
    Super-Hornet
      thanks
      i mean upgrades
      and the motor vibrates when i turn it on
      when i remove the motor screws the inside seems to be turning slowly
        For upgrade, think Hobby Shack had some, just pay them a visit and ask them.
        As for yr hacker, it is the first time I had it vibrate. Try dismatling it from the hornet and spool it at low throttle ..... bent main shaft?
        Mike
          can you write me a procedure PLEASE!
          i dont know the first thing to do
            Step 1. Join a fun fly
            Step 2. Ask people at fun fly to check
            Step 3. Buy lots of Kopi/Tea
            huh
              hmm...20% CP??
              TREX 500 ESP
              Futaba T12FGH
                im in Australia
                were the fun fly which school!?
                theres so many to choose from
                nar serious should i dismantel my motor?
                  ok then don't worry about the funfly check if your motor shaft is bent my hacker does not viabrate 1 bit
                  Helis:Feda,Zap 400
