Hi, Bros.
I'm so curious about 3GX cyclic pitch value and really can't understand why it's become like that..so I need help.
for example
1. In DIR mode set colective pitch +12 ~ -12 with pitch AFR 35%
2. In DIR mode set cyclic pitch 12 with Ail AFR 50% also set same value 50% for Elevator.
3. Progress the other set up menu.(E.Lim A.Lim etc..)
After done all setup, when 3GX in flight mode the cyclic pitch is different with in DIR mode.
I set it 12 in DIR mode But in flight mode the cyclic pitch become more value as 14
So go back to the DIR mode and check the cyclic pitch again, It's still 12.
I have 450 Pro V2, 500EFL Pro, 550E V2..these 3 heli's 3GX are all same. and also test another 3GX..it also same. firmware 1.1, 1.2 both same.
I thought maybe TX problem..so test with KDS K-7X ll, JR XG8, JR 11X..all same result.
So now only what I can do is, just decrease alieron AFR to 40% then can get 12 cyclic pitch. without A.Lim set up again.
Anyway for simple..
In Flight mode cyclic pitch value is more than DIR mode.
if I set cyclic 10 in DIR mode, then in flight mode will be 12.
If I set clcyic 12 in DIR mode, then in flight mode will be 14+
have any idea about this??
help me..
for example
Anyway for simple..
help me..
