My dad has this X-3810 , from JR PROPO. but the original module operates on 29mhz ( ultra rare frequency ) . Does anyone here know how to change it to 2.4ghz so its easier for me to change receivers?
2.4ghz conversion for JR-X3810
Originally posted by TheCloudyNoob View PostMy dad has this X-3810 , from JR PROPO. but the original module operates on 29mhz ( ultra rare frequency ) . Does anyone here know how to change it to 2.4ghz so its easier for me to change receivers?
Spektrum 2.4G module for JR from RCS or Jethobby.
if you want something good with reasonable price, then you can consider Hitec 2.4 module for JR from Rotor. Hitec 2.4G RX is very good price.
Originally posted by Leo View PostIf you want to plug and play then you can consider
http://shop.rotor.com.sg/show-detail.asp?prodid={BF0B1DAE-FDEC-40AC-9153-977BA17E20C2}&pn=2
Possible. It is like normal PCM or PPM 9 channel TX can control 4 or 6 ch rx. What happen is that the TX continue to send signal for 7,8,9 ch but the 6ch RX only receive up to 6 and ignore ch 7,8,9.
Also the Spektrum and Hitec modules transmit up to 8ch and 7ch respectively if I remember correctly.
it is good you bring your TX to rotor test out before buying.
