Futaba T6J
    Futaba T6J
    Hi all I'm noob here.
    Weather I get a futaba t6j???
    Specs for tat ???
    Wats the price ???
    Does replacement easy to get ???
    Compare to spectrum dx6 ???
    I bought one from shs $210. Very nice. I think better look and quality the dx6. Spec can check from web for both. Someone sell at $140 only
      You may want to read more before buying.
      Specs for tat ???
      Wats the price ???
        Where people suggest t6j as a tc for park flyer but Futaba clearly stated it is a full range tx? I have yet to test on a plane or glider. So far tested on boat without any problem at all.
          Yes, it is full range Tx/Rx system.
          I like the built in antenna system, i can just throw it into my car boot without fearing of breaking any antenna, unlike my other std style TX
            So far have anyone tested with plane or glider for long range?
              So far okay. I try on .46 Magnum
                one thing to note, batteries not included.
                Fubata 7C 2.4 + T6XAs
                Charger- Turnigy AC6
                  I searched for range specification all over internet and didn`t find nothing about this rc. So I made a ground test both reciever and transmiter at hand level, visual line, and I managed to get some signal at 1.6 km / 1 mile. And this was just quick dirty testing, I will do some additional testing in future. In air range should be even more.
                    great! by the time 1.6 k i cant see the plane already la hahah i just got a set but yet to test it out
                      This a very good buy. I think people just get confused with FHSS as a park flying only. I am happy with the design
                        There are two techniques DSSS and FHSS. Most remotes are one or another, but FASST remotes is a hybrid between the two, it`s recievers are also a little bit more sensitive from what I read. This doesn`t mean they are xyz times better.
                        Also doesn`t mean that FHSS is seriously inferior or "park flyer only". Most important rule is this: as long there is a visual line (and a clear fresnel zone http://en.wikipedia.org/wiki/Fresnel_zone ) between tx and rx there should be NO problem. For some brutal fpv ranges, you need an amp and directional antenna anyway, doesn`t matter if you are fasst or fhss.
                          i like the fact that i can customize the use of the switches like more ex models. i can change the flap to be controlled by switch A,B or D or the variable knob.
                          only downside to this tx is that the variable knob is too demn inaccessible.
                          i have my own 4 x AA rechargeable batteries but no wall charger. can anyone tell me what charging current I should charge them at since i do not own a quick wall charger and i have to use my rc batt charger which i can set to nimh/nicd?
                            0.5-1c should be safe.
                            So for 2000 mah battery use 500-1000 ma. Slower charging (not too slow) is better for battery.
                            I use eneloop they work great
                              oops, 1000-2000 mah is ok for nimh
