which Rx for Trex??
    which Rx for Trex??
    hi all,
    would lyk to noe which Rx is good for Trex?? GWS??Hitec electron6??feigao??
    Tx will be a Optic 6
    Just my 2 cents:
    - Feigao ......
    - Hitec FM I'm using it on my TREX
    - JR FM Also good but a bit more costly
    - Futaba FM
    Don't think you need a SPCM receiver a 6ch Dual Con. FM receiver will do.
    Good luck.
      I concur with Warbird.
      I'm using Hitec Electron 6 in my eCCPM TRex while using Hitec HFS-05MG in my Flybarless TRex.
      Note that u can use HFS-05MG for TRex but if you have remote gain gyro like Futaba GY401, u can't use HFS-05MG because of it lack channel 5.
      If u have extra Hitec HFS-04MG and u good at soldering, there is a modification to convert it to 6Channels instead.
      Super-Hornet
        BTW... u can use whatever RX u like so long as:
        1 - It has all the necessary channels.
        2 - It is design for air... not land based or boat based.
        3 - It is compatible to your TX.
        4 - Not too big till u can't mount it into the TRex.
        For Feigao, it is notoriously suffers from very short distance or high glitching. But we do have other who claim to be working perfectly. Maybe it is down to luck.
        Super-Hornet
          ok so most probably is the electron 6.... can go wif optic 6
          but wat if it is a GWS rx for later plans then must use wat X'tals? GWS or hitec??
          i will oso lyk to noe wat is SPCM Rx?
          thnkx
