Fms 50a Esc
    Fms 50a Esc
    I wonder if any of you who own A 1.4m FMS PNP which comes with the 50A ESC encounter problem.
    When the ESC is first power up it need to perform throttle calibration. Once done it is supposed to remember the setting, and it can be used in the normal matter, which is not entering into programming mode i.e the throttle is at the minimum.
    Mine seems to have problem remember the settings and I have to go to the programming mode to perform throttle calibration before I can used the ESC. It happens every time.
    Any idea?
    It turns out; 5 or 6 clicks down on the throttle solves the problem. This is strange.
    Apparently, the ESC thinks the tx throttle is not at its minimum.
