If my motor is drawing 18A and I am using a 2200 mAh 3S Lipo, how long will my flight time be? How do you calculate that?
A math problem
Originally posted by dloh View PostIf my motor is drawing 18A and I am using a 2200 mAh 3S Lipo, how long will my flight time be? How do you calculate that?
(2.2/18) x 60mins = 7.333mins
to protect lipos we used up to 80% of capacity so its better to be
(2.2*0.8)/18 x 60mins = 5.866minswww.facebook.com/groups/BRslopers
wow..interesting
Originally posted by Pang View Postassuming your motor average amp draw is 18A, to get your flight time,
When the plane is in flight, depending on the airframe and flying speed , the air passes over the propeller will unload the motor.Meaning if you motor draws 18 amps at stationary , in flight it will draw much lower current between 10 to 30 % lower depending of the aircraft drag factor.
Therefore, a low drag airframe will give you some degree of extra flying time.
So calculating the duration of flight is not so simple.
