How about for a hitec laser 4? Cos I got it 2nd hand in mode 1 but I'm used to a mode2 tx.. I can't just change the spring over, because there's v-tail and elevon mixing. Can someone please advise me. Thanks!
Very easy, Connect throttle to Channel 2, Elevator to channel 3, rudder to channel 4 and ailerons to channel 1.
Jon.. im confused..
if we do dat, we could not control the throttle up and down and the elevator stick will not on the middle on default.
dont u think we still need to change the spring..?
wat i did previously with my gws 4 channel tx is:
since i could not remove the spring (its damn hard and tight to remove.. or maybe i dont have the proper tool... i tot if removing the spring is hard, imagine to put it back? ) .
I unscrew the 4 screws to loosen all the 4 plates and remove the whole plate together with the spring set ONLY and shift to other side.
Really need to be slow and careful coz the parts is like jigsaw puzzle once u unscrew the 4 screws. it took me nearly 3 hrs.... haha
its ok because the rx will think that channel 3 (right stick, up down) is actually the throttle whereas is is now the elevator.(now has a spring so it will centre itself). Rx will oso think that Channel 2 (left stick, up down) is the elevator whereas it is now the throttle. (now has no spring so it will not centre itslelf) As such ur elevator will still centre itself and the throttle will not.(change spring).
