AXI 2208/20
Voltage range 4-8 cells
2-3xLi-Poly
RPM per Volt 1,880 RPM/V
Max. Efficiency 82%
Max. Efficiency Current 8-12 A (>75%)
Max. loading 16 A / 30 s
Internal resistance 89 mohm
Dimensions 27.7x26 mm
Shaft Diameter 3.17 mm
Weight 45 g
Recommended model weight 200 - 500 g
Propeller range 4 cells prop 9"x6"
6 cells prop 8"x5"
8 cells prop 7,5"x4"
Himax HA2015-4100
Dia(mm): 20
L(mm): 34
Wt(g): 48
Shaft: 2
Dia Gear: n.a.
Ratio ESC: 10A
KV: 4100
Rm: 0.141
lo: 0.80
Power: 110
Web Site:
AXI: http://www.espritmodel.com/accesories_axi.html
Himaxx: http://www.maxxprod.com/mpi/mpi-26.html
I will add some more in the future
Super-Hornet
2-3xLi-Poly
Max. Efficiency 82%
Weight 45 g
6 cells prop 8"x5"
Himax HA2015-4100
Dia(mm): 20
L(mm): 34
Wt(g): 48
Shaft: 2
Dia Gear: n.a.
Ratio ESC: 10A
KV: 4100
Rm: 0.141
lo: 0.80
Power: 110
Web Site:
Super-Hornet
