JUST BOUGHT AIR TECHNIC AT-DR6 RX, WHEN TEST RANGE WITH FUTABA 6EXHP ABOUT 20 M ,FULLY CLOSED ANTENNA,THE SERVO START GLITHING.IS IT NORMAL FOR FUTABA?
Futaba 6exhp
May Be the setting
Yo bro,
I also bought a airtechnic receiver with a 40hz xtal. But the problem is the same as you. 1. Check for the receiver dipswitch setting.
2. Check for the compatible unit for the xtal... either single or dual band xtal. Lastly, its the xtal choice cos my tx is a ppm model so have to use dual band xtal.
Hope that all this info is useful for you.
