Hi Guys,
As I had run out of rx crystals, I decided to use the Assan 2.4 system on my recently acquired edf plane. I installed the Assan X8F tx module in my Futaba 8UAP and proceeded to bind the X8R6 rx. No problem at all. I proceeded to connect the edf plane servos to the rx. Test it and taxi the plane in my living room. All system go. The LED on the module and rx is ok. However, when I progressively increased the throttle, the signal is intermittently lost for a few seconds. I could regain back the signal after I moved the servos. Dunno wats going on there.
Presuming that it could be some binding issues, I decided to rebind the rx. Turn off and on the tx. Tx some beeps. Move channel 2 lever up & down and proceeded to power up the rx by connecting bind plug to signal pins at channels 1 &3 of the rx (top pins) and jst lead of a 7.2V nicd battery to the "+" and "-" pins at the "B" channel of the rx.. Suddenly, rx short-circuited . Dunno wat happened there. I could have reversed the nicd battery lead when I insert the jst leads. . My x8R6 rx is gone (burnt smell).
I have another 2.4ghz rx- X8R7. Similar construction but when I look closer there is no "B" channel on this rx. Below are my queries :-
1) Which channel to use in absence of "B" channel on the X8R6 rx to power up the X8R7 rx during the binding process?;
2) Is my X8R7 Rx pins polarity correctly labelled i.e top pin - "signal", middle - "+", bottom "-"?
3) Is there any limitation on the voltage to be used to power up receiver during the binding process without the use of an esc?
Bros, please help. I have tried looking at the youtube video on the binding process but still unsure. I had misplaced the manual but the instruction guide is not very helpful.
Thank you.
Thank you.
