Numbers on the motor..
    Hi all,
    Am trying to understand more of brushless motors...
    Can someone explain or direct me where explanation of the numbers on the motor means? I get the kv part, but the rest i have no clue... eg; like ##-##B 1300kv, or for scorpion motors, ####-#....
    Any help will be very much appreciated..
    Thunder Tiger 50 Titan SE
    YS 56SR wif Hatori muffler
    Align DS610 for cyclics
    JR770T + JR8900G
    JR DSX9
    Mikado Logo 400SE
    Savox BSM 1650KV + CC85HV
    MKS9660 for cyclics
    Mini Vbar 5.2 Pro + BLS251
    JR DSX9
    Kv rating is basically equal to RPM per Volt with no load.
    The numbers in front usually refer to the motor diameter and length.
    Example :
    Motor 3650-1600kv
    Usually Means - Dia 36mm, Length 50mm and KV 1600.
      Example :
      Motor 3650-1600kv
      I see.....
      So meaning to say there is no indication which size plane or heli the motor is recommended to be used for, so long as the dimensions and the spec meets the requirements.....
      JR770T + JR8900G
      JR DSX9
      Mikado Logo 400SE
      MKS9660 for cyclics
      JR DSX9
        If it is some branded motor, normally they would have some recommendation of the size of plane or heli the motor is for.
        So far I saw the following brands have recommendations, Neu motor, Lehner, plettenberg, Hacker, Feigao, Scorpion, Axi, Mega, Zpower and Medusa.
        But if its no brand ones, then its up to flyers knowledge to use the appropriate motor.
