does any know can a DX6I swith from mode 1 to mode 2 ? or when it comes with mode 1 mean u have to stick to mode 1.
dx6i
Even if you use unauthodox method by deliberately connecting the servos to the desired channel on the receiver and moving the ratchet from the trottle to the elevator, you will still be unsafe to use it because when the receiver lost signal or battery power, the safety kicks in and put the trottle channel to zero output, but not the elevator. So the answer is probably a yes and no.
Yes, you can still do all these to make it become mode 2 by swapping the ratchet and servos.
No. Because if you do lost your signal, your trottle will be your original elevator stick position - will not go to zero. However your elevator will go to zero, meaning your plane will probably dive almost immediately. Not safe.I'm Remotely Controlled ...
Originally posted by blueangel View PostEven if you use unauthodox method by deliberately connecting the servos to the desired channel on the receiver and moving the ratchet from the trottle to the elevator, you will still be unsafe to use it because when the receiver lost signal or battery power, the safety kicks in and put the trottle channel to zero output, but not the elevator. So the answer is probably a yes and no.
oh ok thanks for the advice.
Originally posted by GLENDON View Postoh ok thanks for the advice.
Goto the above link. It is for changing mode 2 to mode 1. I suppose it is also possible to change from 1 to 2, and via using the hidden menu.
Very interesting. Perform only if you are well versed .. else $280 gone.
Any more hidden menu we didn't know ? Seems like Spektrum probably had more than one of these hidden menu users didn't learnt about. Why didn't they just put it in the open menu and let user select modes..I'm Remotely Controlled ...
