Lipo Balancer user manual
    Attached is the Lipo Balancer operating instruction
    5889.doc
    Thanks ... needed this
    sorry frank for the masses of sms's working thinsg out
      Frank loves it.
        Frank just got his "new toy" - msn
        Mike
          I'll send you the bill
            Typical 3s wiring with lipo balancers
            I hope this will help
              if i want to add a lipo balancer, that means i must rip open my lipo, unsolder and separate the cells and solder the balancer and then do a heat strink?
              How can i find suck a big heat strink to hold up all the cell?
                U don't need to unsolder and seperate the cells, u can solder the balancer wires to the battery terminals and stick the balancers onto the pack with double sided tape.
                Or u can solder connectors to the pack.
                U can buy big shrink tube from hobby link.
                  Hi James,
                  finally did the balancer and its working well. remember the other pack that i told that could be seriously unbalanced? well, it is, but not as bad. after one session, i charge the voltage of each cell and its alright now Thanks!
                  Hirobo XRB Sky Robo Shuttle [V.O.R.]
                  | Hirobo SRB Quark [M.I.A.] | TT Innovator MD530
                    if my pack is a 2s, do i need to balance it>?
                      Originally posted by blochead
                      Hi James,
                      U R welcome.
                        Any pack with more than 1 cell in series should be check for cell balance.
                          May i know where can i get the balancer? and how much does it cost?
                            SHS sells them.
                              I am using the LiPo balancer on 3 cell packs along with a E-TEC Apache charger...
                              what I noticed is that when all the red LEDs are flashing, the full charge indicator on the charger is still red (charging)... Do I just disconnect my lipos or should I allow the charging to go on until the charger LED turns green??
                              Thanks.
