halo,
Newbie need some help. I am flying the glider with two servo aileron setup. Initially when I got the plane, the aileron setup is quite easy. A Y connector is used to connect both servos and connected to aileron channel in the receiver. After I had some bad crash, I did not manage to get the aileron to work with the same setup anymore.
I actually tested both servos and it working fine. I tested the Y cable too, and it works when i plug in only 1 servo. But if I plug two servos, the servos doesn't move at all, any idea how to fix this?
My tx is dx6i and rx is ar6200.
Thank you guys.
Thank you guys.
