Need to understand abt the reason and working principal , any one can help?
(Enggineers in radio & WLAN question), I am weak in this..
Found this :
DSSS
Direct Sequence Spread Spectrum. The data transmission scheme (sometimes referred to as a "modulation" scheme) used in 802.11b WLANs. DSSS uses a radio transmitter operating at a fixed centre frequency, but using a relatively broad range of frequencies, to spread data transmissions over a fixed range of the frequency band. 802.11a and 802.11g (when not operating in 802.11b mode) use Orthogonal Frequency Division Multiplexing (OFDM).
FHSS
Frequency-Hopping Spread-Spectrum (FHSS) is a spread-spectrum technique used by Bluetooth devices and some 802.11 1Mbps / 2Mbps WLANs. With FHSS, data is transmitted on a radio carrier which hops pseudo-randomly across several different frequencies at a pre-determined rate and hopping sequence. 802.11b devices use DSSS rather than FHSS. 802.11a and 802.11g devices use OFDM.
802.11a
Operates in the UNII (Unlicensed National Information Infrastructure) 5GHz band and supports transmission rates up to 54Mbps. 802.11a uses Orthogonal Frequency Division Multiplexing (OFDM), as opposed to the DSSS or FHSS schemes used in 802.11b and 802.11 networks. Due to its higher frequency of operation, the range of 802.11a equipment is less that of lower frequency systems such as 802.11b and 802.11g. This can increase the cost of an 802.11a network, because a greater number of access points may be required. Since it operates in a different RF band, 802.11a cannot work directly with 802.11b or 802.11g equipment. Using multi-mode 802.11a/b/g access points and/or client adapters will resolve this problem.
802.11b
Currently the most popular and widespread standard for wireless LANs, which operates in the 2.4GHz ISM band and supports data rates up to 11Mbps. Also known as 802.11 High-Rate (HR) and as Wi-Fi, 802.11b uses the DSSS spread spectrum transmission scheme, and operates at data rates of 1Mbps, 2Mbps, 5.5Mbps and 11Mbps.
802.11g
The latest in the 802.11 wireless LAN series, 802.11g operates in the 2.4GHz ISM band and uses Orthogonal Frequency Division Multiplexing (OFDM) to support data rates up to 54Mbps. 802.11g equipment, also known as 54g™, 802.11g can also fall back to 802.11b operation. Therefore an 802.11b device can work directly with an 802.11g device using 802.11b mode.
OFDM (Orthogonal Frequency Division Multiplexing)
OFDM employs multiple overlapping radio frequency carriers, each operating at a carefully chosen frequency that is Orthogonal to the others, to produce a transmission scheme that supports higher bit rates due to parallel channel operation. OFDM is an alternative transmission scheme to DSSS and FHSS.
My Question:
FHSS & DSSS using Operates in the UNII (Unlicensed National Information Infrastructure) 5GHz band and supports transmission rates up to 54Mbps. Is it a illegal band wave that we are operating?
Places where by heavy w bluetooth devices (e.g. trade fair and exhibition hall) 2.4G on rc cars, rc planes (rx/tx) will not be function properly am I correct?
Simple explaintion of OFDM function and operation anyone can explain? or refer link in internet for explaination
Both FHSS & DSSS why or which one can be on surface water? (Tested some 2.4g in bedok resivour on sail boat, some can use why some can't) is it got to do with the any of the design above?
Thanks
Found this :
DSSS
FHSS
802.11a
802.11b
802.11g
My Question:
Thanks
