Hi all, would like some help on how to set up for JR radios 9X. I recently bought a new plane and realised it uses two servos for separate elevator control. tried several mixings but still cant get it right.
Wat kinda mixing should i do so i can achieve an even up and down control of the elevator and able to trim it as together. i tried putting one side into elevator and the other into aux channel. but the travel distance not very even and also when i trim the elevator, the aux channel doesnt move together. how do i troubleshoot ? is there some kind of different mixing i should use? If i use Y wire to connect both servos, it will end up in different directions of the elevator. How should i do it?
Thanks...
Thanks...
