Spektrum DX7 using GP Rechargeable Batteries?
    Is it possible to use AA GP reachageable NIMH batts on this TX?
    I use them for my esky TX but dont want them to go to waste aft i switch helis.
    Inventory
    Honey Bee FP (Retired)
    SJM 360 (Trying to sell)
    Cessna 182. A joy to fly. (In the trashcan)
    DX6i
    It is possible.. But u need to get a battery holder.. That is what im looking for too..
    Does anyone knows where to get a battery holder for Dx7? What is the female white plug called?
    AR Drone 2.0
    Walkera Ladybird Micro Quad
    Jr XG8 Tx (Mode 1)
    RG831B Rx
      i heard in rr that spektrum makes them but i cnt seem to find it in LHS
      Inventory
      DX6i
        try sim lim tower basement electronic shops
        got battery trays in all shapes and sizes.
        good luck!
          i think rotor may have the jr ones.. it shld be the same..
          if not, buy a hitech one ... and diy a connector using those servo tabs. careful abt the polarity though
          For sale
            I have a Hitec battery tray.. But cant fit.. Worse comes to worst i'll have to search for it at SLT.. Anyone using DX7 with other types of battery holder that could fit?
            AR Drone 2.0
            Jr XG8 Tx (Mode 1)
            RG831B Rx
              You can go Rotor to get the tray. It the same tray as JR. If you worry cant fit in, you can bring along your Dx7 along to compare before you buy.
                DX7 uses JR casing so 99% should be able to fit ba
                Inventory
                DX6i
                  Thanks Guys! Maybe tomorrow i'll make a trip down to Rotor..
                  Wonder how long does a fully charged 2300mAh AA battery last in the DX7..
                  Anyway, does JR Tx batt connector uses the same as Spektrum?
                  AR Drone 2.0
                  Jr XG8 Tx (Mode 1)
                  RG831B Rx
                    im not sure
                    you should bring ur tx along and try
                    actually its better to use the battery pack cos the contacts are much more secure compared to AA which can move around
                    im sure noone wants their tx to suddenly restart lolz
                    try le can tell us how long ur tx last?
                    Inventory
                    DX6i
                      Eh.. If im not wrong, the Tx batt packs are also AA batteries soldered together.. That is y its called packs.. If i cant find the battery holder, i think i'll take a trip down to SLT and get the connector for the batt to Tx and i'll solder the AA batteries myself..
                      AR Drone 2.0
                      Jr XG8 Tx (Mode 1)
                      RG831B Rx
                        i was using a modded hitech one leh in my 9x2 before i switched over to Lipo.. it tight but can still squeeze it in..
                        if not go lipo lor
                        For sale
                          i think you should try the one for jr at rotor first
                          the outer case is the same after all
                          battery in battery packs do not have the little thing sticking out on the positive end. they're flat for easy soldering and a more uniform shape.
                          i think if you solder it then it defeats the purpose of having a battery box coz the whole point of it is so that you can remove the batteries piece by piece
                          if ur gna do tt then might as well get another spare battery pack
                          Inventory
                          DX6i
                            dun think nimh lasts v long.. i was using 2700s..for my 9x2 typically charge once a week.. so maybe 5minx4flightsx4days = 80min. plus some time sim and maintence time.
                            so maybe 100++min altogther? btw i used charge them when below 10v
                            For sale
                              eh...ur tx how mani batts ar?
                              maybe u overdischarge it too often den capacity go down?
                              Inventory
                              DX6i
