I'll come by sometime or maybe this Friday to collect them. Any gassing this friday?
Looks like its going to be F18 maiden for me this Friday.
I have used the 18AWG wires on the batt end of the CC25P and when testing the AXI 2212/34 w 10x7 prop, the amp draw was 10A. There was no heating up on the wires at all. Hope it stays that way, otherwise I'll be the first to have a foam F18 melt down in the air...
Hi, I think you don't need 10X7, use 9X7 is good enough, draw lower amp, try to do this experiment.
Weight your aircraft...500g etc... then put a 9X7 prop, hold your aircraft vertical, hit full power, if your aircraft can float upwards, you already have more than 1:1 power to weight ratio,
adding more dia and pitch to prop thereafter will only load your system, generating more heat and shorter fly time.
If 9X7 cannot make it then go higher dia and lower pitch etc...
Originally posted by Airborne Hi, I think you don't need 10X7, use 9X7 is good enough, draw lower amp, try to do this experiment.
