Futaba 2.4GHz FASST 6EX, 7C and TM-7 Service Advisory
The issue related only to Futaba 6EX 2.4G, Futaba TM-7 module and 7C FASST systems. If anyone face similar issues with their Futaba 6EX 2.4G, Futaba TM-7 module and 7C FASST systems, please bring them back to:
Singapore Hobby Supplies Pte Ltd
150 South Bridge Road,
Fook Hai Building, #B1-23.
Email: sales@singahobby.com
As this is not a widespread problem, we have test station at Singapore Hobby where you will be able to determine -- within a matter of minutes -- whether or not your transmitter is affected, at no charge to you. If you prefer, you may send it in to us and we will analyze it for you at no charge. If any problem is found, it will be replaced.
If you have questions or concerns, please do not hesitate to email to sales@singahobby.com or you can PM me.
understand that some updates can be done to the tx to prevent it from happening.. even if my set des not have the zguid , is it possible to send it back to update the tx ?
I am using the TM-7 transmitter module on a 9C. Can or did Futaba published the serial numbers of the affected sets somewhere ? So that we can say, log on to this site to match the s/n. I supposed this will save us loads of trouble of going down to SH to have the set checked eventhough it is only a few minutes.
Sure. To determine if your transmitter might be affected, look on the bottom of the transmitter case. If using the TM-7 module, the serial number is located on the inside portion of the module:
6EX: A7xxxxxxx without the "I" (Inspected) sticker
7C 07xxxxxxx without the "I" (Inspected) sticker
TM-7 07xxxxxx without the "I" (Inspected) sticker
It is important to note that the precautionary measures are relevant only to the Futaba FASST items with serial numbers as described above.
What I meant was can Futaba list down the exact s/n (for example 07212345) at their website. My module is of s/n 07.... but without the 'inspected' sticker. But that doesn't mean that my set will be affected. After all, TM-7 was introduced in 2007, hence all TM-07 will have s/n beginning from 07... with only a small handful which are 08... (2008 mfg).
At least Futaba can do us (disgruntled customers) this small service to save us some trouble.
I understand your point and we will feedback to them.
I think this point may have been considered with the Service Advisory, but the Advisory has stated that the cases are not common while Futaba is still taking precautionary measures. In such a situation, a check at the service centre is probably the most appropriate measure.
