Pcm Vs Ppm
    Pcm Vs Ppm
    Which is commonly used?For airplanes.I cannot decide which to use
    Plane 1:
    FreeWing F-15
    Plane 2:
    GWS Blue Angels C-130 (EDF)
    Another question,My Rx is a 6 channel one,but y do i have 7 channel?
    Plane 1:
    FreeWing F-15
    Plane 2:
      chances are its for the batt supply to the rx.
      ppm or pcm,
      last time, there is fail safe function only for pcm,
      now, newer ppm rx most have it too.
      really depend on your preference.
      XRB SR Lama
      Robotis Bioloid
      Robot Bear
        wa for batt pack.Is it for the use of nitro birds?or Ep oso need?if need then very heavy sia.
        Plane 1:
        FreeWing F-15
        Plane 2:
          you may want to tell us your rx model ?
          high chance doesn't mean it is.
          for electric plane, normally the rx power is supply via the esc, or bec.
          for nitro, will need a rx batt to supply power to the rx.
          XRB SR Lama
          Robotis Bioloid
          Robot Bear
            oh. im using sanwa Infinity 660,which i heard its a veri old model.haha
            Plane 1:
            FreeWing F-15
            Plane 2:
              I have a 35MHz module too.Can i just use any 35.xxxFM crystals?
              Plane 1:
              FreeWing F-15
              Plane 2:
                yes, just match the same freq xtal on both tx/rx, make sure the tx is set to ppm or fm. try to use the same brand of rx and xtal to avoid freq problem, best is to bring your tx down to shop to test and buy.
                XRB SR Lama
                Robotis Bioloid
                Robot Bear
                  i see my tx mode only got ppm and pcm(ps,i 1st time use digital tx)u mean ppm dont need crystal?
                  Plane 1:
                  FreeWing F-15
                  Plane 2:
                    tx need a tx xtal.
                    rx need a rx xtal.
                    both ppm or pcm.
                    just bring yr tx+module and rx down to any dealer/LHS, call them first to
                    check if their xtal can use for sanwa, then go, don't waste time. they will
                    match the xtal for you.
                    xtal is around $15 - $25 per piece ? not very sure
                    XRB SR Lama
                    Robotis Bioloid
                    Robot Bear
                      tx need a tx xtal.
                      rx need a rx xtal.
                      both ppm or pcm.
                      Thanks alot!
                      Plane 1:
                      FreeWing F-15
                      Plane 2:
