Futaba 9C TX Module
    Futaba 9C TX Module
    I am using a 29MHz TX module on my Futaba 9C. If I wanted to switch to 72MHz, is it just a simple matter of getting a 72MHz TX module ? Is there any need to do any configuration changes on the transmitter itself ?
    Up... Up... and AWAY !
    Yup.. that's all that you need to do.
    Just becareful when you pick a channel, crystals for some channels are not carried by rotor... (not sure about other stores)
    huh
      Thanks. Just wanted to confirm this.
      Btw, I just checked with Rotor this evening and they are out of 72MHz TX modules.
        Try
        1) subscribe to Tower hobby's mailing list.
        -> that will give you a welcome voucher.
        2) then use the voucher to get your module....
        huh
